  #1001   IP: 2.103.118.121
Old 19-03-2013, 09:00 PM
Default Re: Wheeled Excavator / Rubber Duck
Originally Posted by Exmayor View Post
Rob you might have said before but has your duck got a prolec height watch?
Most New/modern big hiabs have and also have slew restrictors for working hard shoulder/live lane motorway. Daz
My crane has a restrictor that when over the cab will not let you lower the main arm down it's got sensors on the slew and electrickory in the control box
Paul.
  #1002   IP: 151.227.210.224
Old 19-03-2013, 09:03 PM
Exmayor's Avatar
Exmayor Exmayor is offline
Paul.
Alakazam and Piff Paff Poof as the great suprendo said
Hope your ok Paul
Bye eck she's easy on the eye
  #1003   IP: 86.157.169.69
Old 19-03-2013, 09:05 PM
Hope your ok Paul
where did it go
  #1004   IP: 86.182.100.42
Old 24-03-2013, 07:59 PM
No Prolec Daz.
I've posted a comment in the electrocuted banksman thread about the hiab incident.
The problem was not only did they not see the wires, he was actually free on wheels running the varioguard out along the carriageway, missed them going forward but had the arm up higher to not drag the chains on the way back and BANG hit the middle of three cables.
The 132kva are at about 15 metres, my maximum height even with a bucket on gives me over 5 metres of clearance.
  #1005   IP: 86.182.100.42
Old 24-03-2013, 08:27 PM
Got upgraded this last week
No radio, no heater, no cab, and it frikking snowed lads were pissing themselves, reckon they never seen me with so many layers on before.
The bloke who installed the plastic piles and the steel tubes inside them did a really good first class job.
He was not responsible for the non compacted backfill that subsequently got saturated and slipped but he got to sort it out
I've upload the video that the labourer took when I came down off the bench.
When he saw me put the seat belt on before I spragged it cross carriage he knew it was going to be educational and shouted for me to wait while he got the camera.
Doesn't look much but the problem was the high concrete wall at the bottom and the bridge pillar which made it very tight. My conclusion was in the worse case scenario I could lift it out from behind the wall with the duck.
http://www.youtube.com/watch?v=fySc3...ature=youtu.be
  #1006   IP: 86.182.100.42
Old 24-03-2013, 08:51 PM
Originally Posted by cps140 View Post
Well Rob Thats 100 pages!! and almost 1000 posts!!
Keep the pictures coming!!
Thanks Aiden, not much chance of catching Eddies wideboy though, not over the soft and not on here
  #1007   IP: 204.112.37.66
Old 25-03-2013, 04:28 AM
800CLC's Avatar
800CLC 800CLC is offline
I had a similar experience trenching in a water line for my wife's uncle last November with an open canopy 3 tonne John Deere, it was a decent machine but with that cold wind some proper shelter and a heater would of made it more enjoyable.
  #1008   IP: 86.182.100.42
Old 29-03-2013, 02:36 PM
Went back to clear the surplus muck and finish off before lifting the mini digger back out.
Remembered to get a shot from the other side of the pillar to show just how tight it was.
Not the best quality, sorry.
  #1009   IP: 94.5.26.176
Old 29-03-2013, 02:47 PM
JCBJZ145's Avatar
JCBJZ145 JCBJZ145 is offline
Certainly looks tight Rob!
I love the way you used your feet on the levers to sprag her across, top class I hate any machines without track pedals, i'd prefer no levers at all. Having one hand on the tracking levers greatly reduces your ability in my opinion.
Ashley.
Where theres Muck, theres Money.
  #1010   IP: 86.182.100.42
Old 29-03-2013, 04:31 PM
I love the way you used your feet on the levers to sprag her across, .
Thanks, a little trick I learned very quickly on the C@t 245 many moons ago, they have a single stick to direct travel so to sprag you had a foot on the travel pedal, a foot against the lever and both hands on levers ( not joysticks on the first 245 ).
It was a trick that came in very useful in the tunnel on the Atlas excavator as that was very similar. Left a few lads with their jaws on the floor first time they saw me do it, looked a bit like I was having a fit the biggest problem in a situation like I was with the mini it can all go wrong very quickly and you need your hands where they should be not where you need them to be.
