Go Back   The British Construction Equipment Forum > EXTRAS > Introductions
  #1   IP: 86.160.69.115
Old 29-08-2010, 11:44 AM
digdeep digdeep is offline
Post Kubota kx41-2v track motor
Hello for the 1st time,
have a track motor on my mini digger that seems to have given up the ghost!
removed the rubber track, motor turns ok until you put a bit of resistance on it with a pry bar or you foot even and stalls the motor
motor hub feels hot like its bypassin internal :-(
motor has no external leaks showning
digger had new hyd pump fitted 2mth ago 600
can you fit seal kits to these motors?
does any on know of any people that breaks this type of machine?
or is it another problem with the spool block or the centre slew mabe
Thanks for your help
  #2   IP: 123.211.244.22
Old 29-08-2010, 11:59 AM
ianoz. ianoz. is offline
Default Re: Kubota kx41-2v track motor
Hi Digdeep ,Welcome to the forum James ,another member has just posted his problems with his kabota excavator ,so there may be contact details on his post . Ian .
  #3   IP: 90.193.135.64
Old 29-08-2010, 08:26 PM
Welcome aboard digdeep, you dont play on canals do you, only that is the name of one of the groups
Anyway, to your problem. I do believe cps or tc will be the men to answer you properly.
My limited knowledge on track motors is gained on line. I believe there will be 3 pipes to your motors. 1 for flow and 1 for return, which reverse flow for direction change and will be the same size. The 3rd pipe will be a case drain which returns leaking / bypassing oil back to tank rather than blowing the side out of the motor.
There is a small amount of oil allowable through this 3rd pipe, if you have a lot, then the motor is in need of some tlc or a big hammer
Whether they are resealable, rebuildable or throw away able I honestly dont know.
I have no knowledge of this company and only give it for information / investigation, enquiry purposes http://finaldrives.co.uk/
  #4   IP: 86.150.13.131
Old 29-08-2010, 08:51 PM
Guest1 Guest1 is offline
Humpty Dumpty sat on a wall and allong came Lord-Sean on a Drott and smashed in to the wall,Humpty split in half and the street was spatterd with blood and yolk.Welcome.If you have just had a new pump fitted at least it should eliminate that from the things to check list.
  #5   IP: 77.86.75.91
Old 29-08-2010, 10:07 PM
treble99 treble99 is offline
theirs a kx36 one on ebay 300 i would think thats the same as the 41?cheers steve .
  #6   IP: 86.160.69.115
Old 30-08-2010, 06:22 AM
ebay one is a diffrent style
41-2v has the longer tracks with it being vari tracks
and must need more grunt to move.
thanks for looking
  #7   IP: 77.86.75.91
Old 30-08-2010, 11:05 AM
yes i no they have a longer track base i have had enough of thembut i thought they might of utilised the same motor dont no why with them but they always turn poorly when in two speed tracking as do the 41/3 that i have yet the jcb 80.18 dont have a problem yours isnt stuck it two speed is it?just worth a check cheers steve
  #8   IP: 90.210.71.43
Old 30-08-2010, 08:55 PM
strott strott is offline
Surely both motors would play up if the machine was stuck in two speed?
I know what you mean about the 41-3 not liking turning in higher speed but then again nor do my track dumpers!!
Does your 8018 have auto kick down?? If so then it most likely turns off the high speed when you turn and then kicks down into higher speed again, hence its ability to turn in high speed mode.
  #9   IP: 77.86.75.91
Old 30-08-2010, 10:07 PM
not sure if it does its a 2008 model? it has a switch on the dash but weather it disengages when you turn or not ime not sure?
  #10   IP: 86.150.13.131
Old 30-08-2010, 10:44 PM
In my opinion the 2 speed tracking was-low speed for traveling over rough ground dozing and general dutys and the higher speed was just for covering ground in a straight line say from one end of a site to another,same rules on the older track loaders
