  #1   IP: 51.7.99.55
Old 30-03-2020, 09:24 PM
garycroucher garycroucher is offline
Default Volvo EC25 losing hydraulic fluid
Hi all, my Volvo E25 has been losing a lot of hydraulic fluid from the undercarriage for months I have to top up constantly. Does anyone have experience of this type of seal repair or can anyone offer their services im in the ME9 area postcode of Kent. Thanks
  #2   IP: 92.16.143.85
Old 03-04-2020, 11:02 AM
Default Re: Volvo EC25 losing hydraulic fluid
One of our volvo ec25 had a leak under belly plate was a fitting that hadn't been tightened properly, machine was only two weeks old, we have had to replace rotary coupling seals on one also
  #3   IP: 176.254.229.234
Old 08-04-2020, 08:17 PM
Pedrod316 Pedrod316 is offline
off topic a bit!
I have a volvo ec27d, the hydraulics seem to be getting rougher harder to operate smoothly all the time ? only got 120hrs on it, anyone else had any problems on there volvo?
  #4   IP: 92.16.143.85
Old 08-04-2020, 11:38 PM
We have two 27 one nice and smooth there one deals like digger is bouncing all over the place ,awful to drive, been like that from new but getting worse, build quality on them is poor it's as if it's cavitating oil very jittery to drive, keep an eye on boot that hold bottom pin on swing post is place as they have a habit of coming loose and pin drops out
  #5   IP: 176.254.229.234
Old 09-04-2020, 07:50 AM
Thatís interesting, have you contacted volvo about it? I have a engcon unit on it aswell and itís making that rough to operate now as well, piss poor for new machines....
  #6   IP: 92.16.143.85
Old 09-04-2020, 08:41 AM
Don't think they were to interested said they would look at it next time they were over here haven't seen them yet had oil leaks and loose fittings from new, but other one was spot on obviously pdi by different people, metal work doesn't like salt air up here rusting pretty quick
  #7   IP: 212.88.42.35
Old 19-04-2020, 10:37 AM
Looks/sounds like Ovlov have caught a bad dose of complacency from Bamfords
hydraulic leakage
