  #1   IP: 86.174.71.175
Old 11-06-2020, 12:07 AM
Zetor Ad Zetor Ad is offline
Default JS130 Rotary coupling leak
Hi Its a 2002 Machine 9000hrs, it started leaking out of the top seal so we changed the seals we’re changed (approx 1000hrs ago) and started leaking again out of the top seal so rather than changing the seals again we bought a used rotary coupling just in case mine was worn.
After Just a few hours work the new rotary coupling has started leaking
Does anyone have any ideas, both track’s have loads of power and tracking straight??
