  #1   IP: 81.103.66.177
Old 20-03-2021, 10:21 AM
earlgray's Avatar
earlgray earlgray is offline
Default Inlet and outlet auxillary feed
Hi I have a new pecker which came with pipes loose in the crate. The pecker has in and out on the pipe boss so that's easy. How do I know which is in and which is out on my machine? Pecker pipes did not have quick fittings so I have those to fit.
My assumption is the flow/inlet to the pecker is female on digger male on the pecker, this runs left side of the boom from inside the cab.
Colin
