  #1   IP: 81.157.45.74
Old 29-10-2010, 06:02 PM
Default hydraulic saw
we demoed one of these yesterday ,as clancy's are thinking of buying some
we had two cutouts to do on an 8" cast iron water main
the main was off ,but had a fair head of water and would have been time consuming with a disc cutter ,cutting a window and waiting for it to drain etc
with this i did two cuts in under 5 mins ,with no bother at all
great bit of kit
http://www.youtube.com/watch?v=nXJj3yctpzc
  #2   IP: 90.207.42.192
Old 29-10-2010, 07:48 PM
strott strott is offline
Default Re: hydraulic saw
Nice,
Dumb question!!: Why do you need to stop regularly when using a disc cutter?
What did you use to power the saw with? excavator? hydraulic power pack?
  #3   IP: 81.157.45.74
Old 29-10-2010, 07:56 PM
Originally Posted by strott View Post
Nice,
strott , with that amount of water in the main ,the disc cutter lacks the power to continue cutting ,then the belt get wet and slips
it was powered via the hammer circuit on the 3cx
cheers graham
  #4   IP: 82.37.48.29
Old 29-10-2010, 08:58 PM
Exmayor's Avatar
Exmayor Exmayor is offline
Graham we had a couple of these with Barhale, as long as they're looked after i think they're bloody good tools. We powered them off beaver packs.
  #5   IP: 92.40.108.20
Old 29-10-2010, 09:04 PM
rubber duck rubber duck is offline
Smile Re: hydraulic saw
brilliant for water no good for us on gas graham.unless its dead and its getting ripped out .andy
  #6   IP: 81.157.45.74
Old 29-10-2010, 09:06 PM
we have a power pack ,plus a block with pipes to fit the kubotas ,and then pipes to go on the jcb,s
rumor is that only a select number of people are going to be able to use it
so it will hopefully be looked after
also heard they have gone over to komatsu mini's
  #7   IP: 90.207.42.192
Old 29-10-2010, 09:14 PM
ahhhhh, belt slippage, didn't think of that obvious when you think about it
Who is going to Komatus minis? Clancy Docwra??
  #8   IP: 81.157.45.74
Old 29-10-2010, 09:15 PM
hows things with you mate keeping busy
must admit to the odd mistake identifing mains and knicking the gas with the disc cutter
when on mains rehab ,a gang in sevenoaks ,were lining a 4" cast main
they found main in edge of footpath in the high street and put a small cut in water comes out so he winds the saw through it ,only to find a 2000 pair bt cable in it
  #9   IP: 81.157.45.74
Old 29-10-2010, 09:17 PM
yes ,so i hear ,not be happy with some other makes
  #10   IP: 82.37.48.29
Old 29-10-2010, 09:25 PM
Exmayor's Avatar
Crikey hope they are getting them cheap, it's like tying one arm behind your back i am not a "K" fan.
