  #1   IP: 2.29.11.79
Old 28-12-2013, 07:52 PM
Default Dipper mirror
Saw this on another site. It appears their dipper cameras have broken so they have replaced them with a convex mirror. Whilst not as clear as a screen in the cab, a lot cheaper and because of the extra wide angle it has the added advantage of giving a view down either side of the machine.
What do you think?
  #2   IP: 92.40.210.80
Old 28-12-2013, 08:15 PM
Default Re: Dipper mirror
Seems a good idea. Looks like it's set for the operator to apply his mascara or lipstick. Needs to be looking at the bucket surely ? or are they used just for looking into holes ...?
Camera is a damn good idea. First i saw was on Ollies PW.
  #3   IP: 86.135.113.65
Old 28-12-2013, 09:33 PM
Trax, they are supposed to be looking down at the bucket when viewed from the operators seat, so you can see in holes, over the sides of wagons etc.
  #4   IP: 81.152.64.111
Old 28-12-2013, 10:04 PM
nice ,but as soon as i fold the breaker up ,its gone
  #5   IP: 188.31.193.122
Old 29-12-2013, 12:05 AM
Camera under the boom then Graham .... although, i think that maybe you don't really need one .... you've had a little bit of work experiance I thinks.
  #6   IP: 81.158.104.253
Old 29-12-2013, 01:17 AM
vinpetrol vinpetrol is offline
Camera under the boom then Graham .... although, i think that maybe you don't really need one .... you've had a little bit of work experiance I thinkk.
I love the syinical eyebrow raising you bring to the forum Trax
I can't help but burst into a wry smile with some of your posts .
I think I must be getting longer in the tooth !
Vin
  #7   IP: 92.40.212.47
Old 29-12-2013, 07:10 AM
Hi Graham, i do understand the concept, it just didn't appear to be directed down to the bucket area. Should the need arise i would fit one or more than likely a cctv system.
  #8   IP: 92.40.212.47
Old 29-12-2013, 08:45 AM
Vin
Thank you .... I have to say I was not in any way making lite of Grahams post, the wink was the fact he knows I think he's a top class operator.
As for long in the tooth i only have one or two years on y'self .... so what does that make me .....
  #9   IP: 81.152.64.111
Old 29-12-2013, 09:57 AM
steady on now i would not go that far
  #10   IP: 2.29.9.40
Old 29-12-2013, 11:41 AM
We often load ro-ro bins and they are too high sided to see what is going on. A good operator will make a fairly even load no problem, but I like to check what I'm doing, which means getting out of the cab and climbing the side if the bin, which all takes time. This seemed like it may be a cheap solution, without going to the expense and hassle of a boom camera.
